High Idle
Old Dec 11, 2008 | 09:45 AM
dynomite's Avatar
Default High Idle
I can't figure this out. No one can. I have a 99 disco 1 with 120,000 miles. in the morning i crank it and it always is up at 2000-2500 rpm's. put it in reverse or drive and it drops to around 1000-1200 rpm's. lately if i stop the engine and crank it again sometimes it will idle around 750 and sometimes it will run high again and the crazy thing about it, is that some times when i've done a lot of turning the engine on and off it'll idle really low and when i put it in drive or reverse, it'll die.
so, i've cleaned the stepper motor. i've tried another one. no difference. i've changed out the entire plenum, including throttle body and cables. not difference. i've checked for a vacuum leak with carb cleaner and i've had a land rover mechanic check for vaccum leak. nothing found. is there something i'm missing. does anyone have suggestions. oh yeah, i've checked around the site, and i haven't found anyone with a high idle problem like mine. or a good solution. thanks for helping.
jason
Old Dec 11, 2008 | 05:09 PM
Default RE: High Idle
Did you replace the steepre motor with a new one or a used one?
Old Dec 11, 2008 | 06:29 PM
dynomite's Avatar
i found someone with a used one. put it on real quick and the same high idle. jason
Old Dec 11, 2008 | 07:31 PM
If you know that the other one was good...then I would lean towards a vacum leak.
That is the only think that I can think of.
Old Dec 15, 2008 | 09:50 AM
dynomite's Avatar
would a truck with a vacuum leak every run at a low idle? seems like when it's warmed up, it'll run low. does this give anyone any ideas?
Old Dec 15, 2008 | 12:55 PM
Depending on the vacum leak it can run at a really low idle, not idle, or a really high idle.
Because it idles high when cold and then normal when warm I am guessing that the leak closes when whatever is leaking expands from the heat of the engine.
It expands and plugs the leak, when cold the leak is open again.
wick_60010
Nov 22, 2017 04:25 AM
omarica7
Mar 11, 2014 08:12 AM
rravenn13
Jul 19, 2007 04:40 PM
disco boy
Sep 18, 2006 10:30 AM
Brad S1
Jul 7, 2006 02:13 AM
