High Idle (3000) rpms
Old Aug 4, 2008 | 03:18 PM
tommytwotone's Avatar
Default High Idle (3000) rpms
My idle is really high... like 3000 rpms.. when It starts it starts decent then jumps to 3000 rpms real fast. I have replaced the maf and tps... can anybody tell me any other ideas that I might want to try. Thanks
Old Aug 4, 2008 | 04:06 PM
Default RE: High Idle (3000) rpms
Need to know if it is a DI or a DII.
Old Aug 4, 2008 | 04:13 PM
britishracinggreen's Avatar
Probably a vacuum leak. Check the vacuum lines around the intake (there are several). If you need help call me at 867-5309.
Old Aug 4, 2008 | 04:36 PM
Hey guys thanks... Its a d1... I have checked all the vacuum hoses around the intake and have repaired all of them... Unless there are some that are hiding I think I got um...
thanks for the offer of the call. would you happen to have an area code. Thanks again
Old Aug 4, 2008 | 06:13 PM
Also clean your t/body and lube your cable to make sure they are not causing your high idle.
Old Aug 4, 2008 | 09:24 PM
okdiscoguy's Avatar
don't you have to
Old Aug 4, 2008 | 09:25 PM
okdiscoguy's Avatar
use testbook to re-learn
Old Aug 4, 2008 | 09:26 PM
okdiscoguy's Avatar
the new TPS sometimes?
Old Aug 4, 2008 | 09:36 PM
roverguy7's Avatar
t4 is needed to adjust it properly, but it shouldnt cause anything that dramatic, it sounds like a sticking idle air valve to me
Old Aug 5, 2008 | 12:13 PM
The last sentence in my previous post was a joke in reference to your user name.
