High Idle. All I did was change spark plugs.
Old May 31, 2010 | 11:29 PM
Spencerfitch's Avatar
Default High Idle. All I did was change spark plugs.
Ok so today I changed my spark plugs and my one broken wire. It ran great!! However later I go to start it and its idling at 1,500rpms..
A buddy of mine touched the throttle sensor and it seems to fix it. But later on it idles high again. Cant fix it. No touching pushing taping or disasemble and oil of the throttle sensor works. And the throttle sensor seemed to turn just fine..
All I can say is I did change my spark plugs.. To bosh +4. And one spark plug..
On a side note it has alot more acceleration.. I would love to say it was the spark plugs. But it might just be the high idle.
Old Jun 1, 2010 | 12:02 AM
TBIAgent69's Avatar
Is there anything preventing the throttle from returning to normal? Is there a check engine light? Have you checked / cleaned your IAC motor?
It could also be a vacuum leak... take some brake cleaner and spray it around the motor until you find a change in the speed.
Old Jun 1, 2010 | 12:17 AM
WELL..
I just got done cleaning the throttle body. Few days back.
Im begining to think my check engine light doesn't work... Should it show when key is turned to the "on" position
I found three hoses that need replaceing so Ill check into it after Im done with that..
two are breathers one is the fuel pressure regulator hose.
Old Jun 1, 2010 | 12:25 AM
ok check engine light does work. But no its not tripping.
Old Jun 1, 2010 | 07:58 AM
First, what year, model and mileage?
If it is a D2, when cleaning the t/body, did you clean the idle control solenoid?
Check your air tube to the t/body, some people crack the fitting, on a D2, that goes to the idle solenoid.
On a side note, when one wire is weak enough to break the others are all probably getting old and should be replaced with new 8 mm wires like Magnacor's or STI's.
Old Jun 1, 2010 | 10:27 AM
Its a d1
Im going to replace the wires with better quality which is why i only replaced one.
Im going to the junk yard to find a Idle Sensor
Old Jun 1, 2010 | 04:01 PM
I just changed the idle sensor and nothing.
Then I cleaned the IAF Or stepper motor and nothing.
Disconnected battery and will see where that gets me.
Then going to check for vacuum leaks.
I found a Bulging coolant hose coming from the engine to the heater core. Any reason for this? Yes I know to replace it.
Old Jun 1, 2010 | 06:09 PM
I did an induction cleaning with seafoam. It seemed the idle dropped to 1000rpms. I was super excited and happy. But then...
I kille it and started it again and its back up to 1800
Old Jun 1, 2010 | 06:27 PM
03discoman's Avatar
some plugs dont work with out discoverys...
i used 4 different kinds of plugs..even bosch plat 4 .....only the stock plugs worked untill i upgraded my wires....then i could run bosch plat 4 without problems
Old Jun 1, 2010 | 07:05 PM
The +4's take LOTS of juice to run correctly.
Personally I prefer Iridium plugs because they require very little juice and the way I figure it the less power my coils have to put out the longer they will last.
But each to their own.
