High Idle is back.
Old Jun 13, 2010 | 10:04 AM
Spencerfitch's Avatar
Default High Idle is back.
I was so happy I fixed two things yesterday...
Now its back. What exactly controlls this? I can get a new ECM for dirt cheap. But I will still have to get it reflashed.
ONLYTHING I did yesterday was remove the brake caliper and wash underthe hood. I didnt go extremem just getting some mud off.
WWWHHHYYYYY!!
Old Jun 13, 2010 | 10:09 AM
Clean your t/body and IAC and this should take care of it, if not, you may need a new IAC.
Old Jun 13, 2010 | 10:20 AM
If you remember I just fixed this problem. Had the ECM reset. Now it's doing it
again but new characteristics. It does seem to die down bit I noticed while idling at a stop light it would rev and fall rev and fall. Like I was hitting the gas. It wasn't holding for long I mean like 1/2-1 second of rev the fall same time at idle then rev. I think I'll be getting a new ECM today
Old Jun 13, 2010 | 11:56 AM
I think your ECU got wet.
Since you just had it "fixed" by the dealer take it back, it should still be under warranty.
Old Jun 13, 2010 | 12:08 PM
So, out of curiosity, have you ever done what I suggested, cleaning the t/body and IAC, if so did that do anything for you?
Old Jun 13, 2010 | 12:20 PM
It's what I did right before it happened tge first time..
I also swapped the iac and tps last time. No change
Old Jun 13, 2010 | 12:21 PM
Man it's acting crazy. Idles up to 2k at start up then dies to 500 bit istantly jumps back up over and over. I got a video of it. After driving it idles right and then after driving some more idled to 1000..
WTF land rover just work
Old Jun 13, 2010 | 12:37 PM
Ok now it's fine... WTH
Old Jun 13, 2010 | 01:43 PM
It sat for 30 mins. Upon startup it's goofy again.
Old Jun 13, 2010 | 02:14 PM
What do yall think
ECM
VSS
FUEL PUMP
FUEL REGULATOR
