High Low Selector Seized
Crawl under from the passenger side front door. Look up where the front drive shaft meets the transfer case above the transmission you see it. If you have a second person inside the truck wiggling the shifter it will be easier to spot. Took me 4 tries over a few days with PB Blaster to get it loose.
Fallstaff
01-14-2014 04:39 PM
growlinbear 2013
01-24-2013 01:08 PM
