High Low Selector Seized
Old Nov 10, 2013 | 12:34 PM
jalodge's Avatar
Default High Low Selector Seized
My High Low selector has seized up but I don't know where the linkage is to spray some penetrating oil on it. What is the easiest way to spray this?
Old Nov 10, 2013 | 01:45 PM
OffroadFrance's Avatar
Did you try to change into low whilst stationary as you need to be moving very slowly I believe about 5mph, check out the plate behind the gearshift. Tip: to ensure the low range changer works when needed regularly (once a month) change into low range for a few miles.
Old Nov 10, 2013 | 02:08 PM
jalodge's Avatar
I have not tried it while moving nor have I ever had it in low since I have had it. The plate says 0-5 mph but I will give that a try.
Old Nov 10, 2013 | 04:50 PM
jalodge's Avatar
I tried shifting it while rolling but same thing, it won't move. I don't want to push it too hard because I don't want to break it.
Old Nov 10, 2013 | 06:35 PM
zski128's Avatar
Crawl under from the passenger side front door. Look up where the front drive shaft meets the transfer case above the transmission you see it. If you have a second person inside the truck wiggling the shifter it will be easier to spot. Took me 4 tries over a few days with PB Blaster to get it loose.
Fallstaff
Jan 14, 2014 04:39 PM
growlinbear 2013
Jan 24, 2013 01:08 PM
old gold
Nov 12, 2008 11:18 AM
old gold
Nov 3, 2008 08:16 AM
fpapai
Oct 29, 2007 12:30 PM
