high RPMs
high RPMs
I did a seafoam treatment early this morning then drove all over town came home car ran great. went to girlfriends house and drove the other car and came home cranked up the disco and at idle it was running around 2500 for solid 10 min. As soon as i put it in gear it drops to normal RPMs. Put it in park right back up. also cleaned the MAF.
Walter
Walter
I'm not real bright, so I'll speculate and you guys yell at me.
If the induction cleaning causes the idle to stumble, (the ECU doesn't understand), will the ECU try to compensate for lower rpm by opening the IAC?
Will the feedback loop on the IAC tell the ECU "I'm wide open you idiot"?
Will the ECU say "screw off" (not literally)
I'm just wondering if there's any correlation with induction cleaning, not holding it to 2000rpm during and the IAC not cooperating afterwards.
luck,greg
luck,greg
luck,greg
luck,greg
When you do the induction cleaning you let the truck idle and do it with a warm engine.
free_kid
13
02-03-2010 12:56 PM
