High Speed Vibration Front Driveshaft Removed
Old Dec 20, 2013 | 12:58 PM
Madlands's Avatar
Default High Speed Vibration Front Driveshaft Removed
I dropped the front DS on my 99 after it started to fail.
I drove it awhile with the center diff locked with no problems.
My issue started after I changed the tcase fluid. I used Mobil1 75w-90(I know I shoulda gone heavier). I had a case on hand though so why not. Anyways after changing the fluid I started getting a vibration when going over 65mph. Keep in mind this is while the DS is removed.
I'm pretty sure I filled it completely full. Could low oil cause a vibration or is there anything else I should look at?
Old Dec 20, 2013 | 01:17 PM
ZGPhoto's Avatar
Output bearing possibly? Have you checked the flanges to see if there's any play?
Old Dec 20, 2013 | 01:47 PM
Madlands's Avatar
I have not! What's the best way to check for play? I'm not clueless I just know some methods are better than others.
Is it not a bit weird I didn't have this issue until I changed the fluid though?
Old Dec 20, 2013 | 01:51 PM
ZGPhoto's Avatar
Could be a coincidence, but how long did you drive without a front shaft? I recently developed a similar issue after driving without a front driveshaft, not sure if it was related as I did go to conclave and beat my truck pretty hard on the trails.
Old Dec 20, 2013 | 03:05 PM
Madlands's Avatar
I drove a good while without it. Probably +3k since it's not my DD my younger brother drove it to and from school for awhile, but never over 45mph.
He's a new driver and unlike myself has never broken a rule, and actually turns his phone off while driving. I know you don't care about him but I thought I should clarify how cautious he is and that he didn't abuse it, before someone jumped in with those accusations.
Have you solved your issue? If so how?
Old Dec 20, 2013 | 04:01 PM
ZGPhoto's Avatar
Haha well I wouldn't say I don't care about him... he's a human.
But that's besides the point.
No I have not, I'm about to fix a motor mount and I'll probably check out the t-case when I'm under there.
Old Dec 20, 2013 | 04:02 PM
dusty1's Avatar
wait a second....is this your brother????
I love that guy
Old Dec 20, 2013 | 04:04 PM
dusty1's Avatar
output check = drop shaft make sure nut is tight (center nut on flange). push up and down and all around. it should only spin.
Old Dec 20, 2013 | 04:38 PM
Madlands's Avatar
I love that guy
Pretty close!
And I'll give that a try dusty. Hopefully the nut is just loose.
Keep me posted on what you end up finding out Zack.
And thanks for the input guys!
Old Dec 20, 2013 | 06:24 PM
dr. mordo's Avatar
I've had a vibration over 65 since I got the truck. It seems to come and go, and so far I've had no luck at all diagnosing it.
I sorta think it's a bearing, either wheel or in the diff. The big difference is mine seemed to go away when I pulled the front shaft. I thought it was the shaft, but with a different drive shaft it's doing a similar thing. And because it seems to be intermittent it's hard for me to believe it's the shaft.
In your case, I'd start with rebalancing the front tires.
xb70valkarye
May 17, 2013 05:55 PM
dr. mordo
Mar 10, 2013 08:58 AM
94svt50
Apr 6, 2012 06:27 PM
mbonthenet
Mar 4, 2012 09:17 AM
bothomasmusic
Jun 17, 2011 11:52 AM
