Hill descent not turning on
Old Feb 15, 2019 | 08:03 PM
Sixseven729's Avatar
4wd High
Default Hill descent not turning on
I HAVE A 2004 DISCOVERY 2 when I push the hdc button nothing happens. I changed the switch and it still did not work nothing no lights chimes or anything. Anyone have any thoughts. I have another 03 disco that HDC worked fine in that I can swap parts just seeing if anyone has a good place to start?
Old Feb 15, 2019 | 09:38 PM
Best4x4's Avatar
I know with the Nanocom Evo you can disable the ACE, SLS, and even the HDC lights, however I think it still works. Are you in 4Lo? On a D2 you must be in 4Lo for HDC to operate it will normally just flash a Green Light and beep in 4Hi.
Old Feb 16, 2019 | 06:02 AM
4wd High
I have been 4 low and first gear no lights or beeping that let's me know it is in Hdc mode I am going to try it on a hill today and see if it is working even though it is not showing me it is engaged. I bought this d2 a week ago and noticed the other day the switch was in the on position with no warning signs or sounds so i wonder if it is working. And what to trace down if it is not working.
Old Feb 16, 2019 | 10:10 AM
Twix's Avatar
Don't need a hill, just give it some gas and let go, it will come on and you'll feel/hear the crunching sounds of the modulator
Old Feb 16, 2019 | 10:23 AM
4wd High
Does not do anything. I know how it works and what it does. The hdc does not turn on tried going down a hill and nothing the engine brake is the only thing slowing the vehicle. Is there a relay or control unit that operates HDC that I can see if it needs replacing I have a 03 parts vehicle that hdc works on but my newer 04 that I am building it will not engage at all no lights or sounds showing it is engaged. I have already swapped the switch and checked wires behind switch to see If that was the problem. But did not solve
Old Feb 16, 2019 | 10:47 AM
Best4x4's Avatar
Someone could have messed with your cluster & disconnected the speaker. Does your cluster make sound if you leave the lights on or key in the ignition?
Old Feb 16, 2019 | 03:32 PM
mollusc's Avatar
have you checked fuse 27?
Old Feb 16, 2019 | 07:05 PM
4wd High
Update I checked the speaker on back of instrument cluster and found it missing I hooked up a cluster from my 03 parts care and low and behold I have the 3 amigos pop up. After further look at cluster I took out some person removed led lights from the board instead of fixing 3 amigos properly. I hooked up my scanner and cleared codes in abs and hdc works perfectly. Not I have to change will speed sensors to fix 3 amigos. Is there anything else I need to change if it is showing all kind of sencor readings?
lilherc
Sep 22, 2016 01:05 PM
roverbob
Jan 16, 2013 12:23 PM
djmitten
Aug 29, 2011 08:57 PM
Scott R
Dec 19, 2009 10:00 AM
kev c
Freelander
Aug 4, 2008 06:06 PM
