HK Speakers
HK Speakers
Ok, so, along with EVERYTHING else my baby has dished out to me, I've got alot of rattling in my from speakers (left/right).... where can I get good Hardon Karmon speakers??? I've looked everywhere and no one sells them!
If I can't get those, in your option which are a great replacement for them?
Thanks!!
and btw... for the HK set up, is it two speakers on the door, or one speaker and a subwoofer??? what's that other speaker..
Thank you so much!!!!!
John-Robert
Thanks!!
John-Robert
RE: HK Speakers
You have one tweeter on the front A-pillar, one midrange in the drivers door and one low-range in the drivers door. Two sub speakers in the rear door, and one wide-range in each rear passenger door. (I think that's all, I haven't taken apart the rear passenger doors yet).
You might want to take the door interior panels off and look for the source of the rattle, it's not too hard.. you just remove all the visible bolts then gently pull the panel away from the door. You'll usually end up needing to replace one or two of the pressure fit pins though, what a bad design... (unless you're selling them at $3 each).
Personally I'm looking at taking all the doors, building new boxes for the speakers and going a bit larger on each but that's probably overkill for most. I am replacing the stock amp soon though, that's going to be fun. I have a KVT-717 and nav and ipod interface wired in now and I'd really like to be able to eliminate more cabling and run more higher quality interconnects in the process.
dherbs85
11-25-2005 02:38 AM
