Hola
Old Mar 11, 2009 | 07:04 PM
basquiat's Avatar
4th Gear
Default Hola
Greetings
I wanted to ask for some assistance. I have had a 1999 DII for about 6 years now (114000 miles). The car has been good overall. I kinda of got used to having the CE light stay on. About 1 year ago i had a local mechanic do a major tune up (02 sensors, wires, plugs, and some other minor work). The car ran fine until about 3 weeks ago when i started noticing radiator fluid always beeing low. I had the head gasket changed 2 years ago and it did not seem like it was leaking too much. I made sure i always kept adding fluid until i had time to research the source.
I was driving one night when i noticed the rpms drop during a stop sign. The car started running rough and at times it stalled and hesitated when applying gas.
I parked the vehicle and read the following codes.
p1184
p0172
p0175
p0103
p0112
p1171
p1174
Thanks to the boards i was able to get an idea to take care of the leak. I changed all hoses, head gasket(although it was not leaking), throttle body heater, thermostat, mag wires and although i bought a water pump i never replaced it(pita). I recently drove it and it seems to be holding radiator fluid. The car still showing codes and still idles rough at times. The last time i changed the MAF was about 4 years ago. Wondering if it could be the MAF again. Please advice. Thank you gents
Rafael
Old Mar 11, 2009 | 10:05 PM
roverguy7's Avatar
sounds like a mafs
Old Mar 12, 2009 | 09:37 AM
okdiscoguy's Avatar
What king of air filter are ou running? Did they try to clean the MAF when the did the tune up? I agree with Dave, sounds like a MAF....
Senormac
Apr 29, 2015 08:28 AM
wasserboxer
Jan 9, 2013 07:31 AM
Snafu / Disco Fries
Dec 24, 2012 12:08 PM
ItsAllGood
Oct 9, 2009 11:42 PM
starcraft
Mar 31, 2008 08:35 AM
