View Poll Results: Buy hood blackout decal?
YES
24
77.42%
NO
22.58%
Voters: 31. You may not vote on this poll
Hood Blackout what is your opinion?
Old Nov 29, 2013 | 10:38 PM
BayerischeDisco's Avatar
Default Hood Blackout what is your opinion?
I'm trying to figure out whether to buy a hood blackout or just use spray paint. What is your opinion?
Old Nov 29, 2013 | 10:55 PM
dusty1's Avatar
The blackout is great ...., perfect coverage ... Blocks the glare...clean set up.
But it can be peeled back.
esthetically it will look better to get the blackout decal.
Old Nov 30, 2013 | 12:39 AM
TRIARII's Avatar
Either or would be good but if you can achieve the same goal for cheaper then paint it. Wont peel back and if you do it right it will look clean. Id do some research on the best paints to use and consider using a couple layers. Should not be difficult task though.
Old Nov 30, 2013 | 12:46 AM
fishEH's Avatar
Plasti-dip. Best if both worlds. Cheap and easier to install than the decal. Just tape off the area and spray it. Don't like it? Just peel it off, like the decal. I have the Vigg Designs decal. It's nice but was a pain to get right by myself. Ended up with a couple air bubbles/specs of dust. Had to tape the deal under the hood at the windscreen edge of the hood to let it dry so it would adhere.
Old Nov 30, 2013 | 04:23 AM
ScreamingLife's Avatar
I second this. I've done this for a long time. Its cheap and its not permanent, which are things I'm all for.
Old Nov 30, 2013 | 09:02 AM
Thanks for the insight so far.
Old Nov 30, 2013 | 09:26 AM
dusty1's Avatar
Baby Hijack.... Now I want to plasti dip mine...is it just clean, tape and spray or is there a lot of masking to do.
Old Nov 30, 2013 | 03:51 PM
Nope, your pretty much covered it. There are a few youtube videos on how to lay down the different coats, but its pretty easy all the same.
Old Nov 30, 2013 | 04:55 PM
antichrist's Avatar
I painted my '95 10 or so years ago. Touched up some scratches once.
Old Nov 30, 2013 | 07:09 PM
mbruneaux's Avatar
I might just have to do this...... it's nice to be able to change your mind.
