hood release
Old May 13, 2005 | 11:47 PM
kram2179's Avatar
Default hood release
I have a 99 Disco II. I recently tried to pop the hood to check fluids and such. The hood wouldn't release..even after multiple attempts. I was wondering if there is any other way to open the hood?
Old May 14, 2005 | 03:24 AM
kirk4's Avatar
Default RE: hood release
Can you move the release? I had to hose my down with wd40 but it worked after that.
Old May 14, 2005 | 07:09 AM
Lighting90's Avatar
You might be able to get access to the cable by removing the front grille, at least you can on a defender. Though you might need to use long nose pliers.
The catch needs to be greased on a regular basis, otherwise the plates stick.
Old May 16, 2005 | 12:34 AM
Bait's Avatar
The cable stretches. You need two people. One to pull the handle, one to push down on the front of the bonnet. This should pop it. Don't close it all the way again without replacing the release cable.
AK Rover
May 1, 2017 11:04 AM
steveo2000
Sep 8, 2015 08:00 AM
jerkshirts2
Jan 2, 2009 11:40 AM
rjmaype
Jan 18, 2008 08:00 PM
Doak
Jan 12, 2007 11:07 AM
