Hoodliner installed with PICS
Old Aug 20, 2015 | 08:08 AM
MPDano's Avatar
Default Hoodliner installed with PICS
My original hoodliner was party being used by the mice, so decided to replace the half eaten liner with some Dynamat. Also, installed two new fluid squirters.
Attached Thumbnails Hoodliner installed with PICS-20150819_094706.jpg   Hoodliner installed with PICS-20150819_094712.jpg   Hoodliner installed with PICS-20150819_094720.jpg   Hoodliner installed with PICS-20150819_114512.jpg   Hoodliner installed with PICS-20150819_115005.jpg
Hoodliner installed with PICS-20150819_115010.jpg   Hoodliner installed with PICS-20150819_115306.jpg   Hoodliner installed with PICS-20150819_115716.jpg   Hoodliner installed with PICS-20150819_115802.jpg   Hoodliner installed with PICS-20150819_121819.jpg
Old Aug 20, 2015 | 08:30 AM
Charlie_V's Avatar
Look nice. Mine has had a tear in I since 2001 when when pulley disintegrated. If you don't mind me asking what did it cost and what did you buy to do it?
Old Aug 20, 2015 | 08:58 AM
MPDano's Avatar
Dynamat Hoodliner part number 11905 $61 on eBay.
Seam Roller at local wallpaper place $8
Windshield squiters $41 for the pair on eBay.
Did this myself without help. Only awkward thing is the width of the hood, but it's pretty light.
Old Aug 20, 2015 | 09:03 AM
Charlie_V's Avatar
That part number is pure gold. Thanks!
I have the hood strut mod on mine... did it add much weight?
Old Aug 20, 2015 | 09:19 AM
cappedup's Avatar
Looks very neat. Nicely done.
So it's stuck to the hood with contact adhesive and rollered down?
As a wider question, what does the liner serve to do? Apart from give rodents nesting material? (I found an old nest in my air filter box and a big chunk of liner missing when I bought mine?)
Is it keeping heat in (seems an odd thing to do, considering the efforts we go to to keep temps low) or stopping sound escaping (also odd, as no extra noise would make it into the cabin, I doubt)
Or is there some other reason to have a hood liner? Only thing I can think of is if the vehicle is regularly turned off and on it might maintain a more constant engine temp, increasing efficiency. Maybe.
Anyone removed it to see how it affects temps? I can fully imagine removing the entire hood would keep things lower, so taking the main insulating part away should do also.
Old Aug 20, 2015 | 09:56 AM
Charlie_V's Avatar
I think it is for noise and to keep your paint a little cooler on top of the hood. Alex_M took his off, if I recall correctly, and suffered no ill effects.
Old Aug 20, 2015 | 10:01 AM
cappedup's Avatar
From another forum.
"Those hood liners are also designed to suppress engine fire. The fire melts the tabs and the liner drops onto the engine giving the passengers an additional few seconds to escape."
Old Aug 20, 2015 | 10:23 AM
MPDano's Avatar
Didn't notice any weight diff when I lifted the hood to re-install.
Old Aug 20, 2015 | 10:24 AM
MPDano's Avatar
Yes, exactly. Plus having to look at a half rodent eaten hood liner was bugging me
Old Aug 20, 2015 | 11:45 AM
Charlie_V's Avatar
Originally Posted by cappedup
From another forum.
That's interesting. Thanks for the quote. I hadn't thought of that.
Now that I think about it... the hole in mine (from an exploding pulley and belt), which has been there for over a decade, leaves no part of the hood looking strange.
