Horn Quit Working!?!
Old Nov 18, 2010 | 11:29 AM
southernrover's Avatar
Default Horn Quit Working!?!
Hey Everyone,
I have a 2004 Disco II S. And... randomly... my horn stopped working. For a while, if I hit the horn on the steering wheel it made a very faint noise. Now, it makes no noise at all. Should I just change the fuse out? Which fuse? If not, is it really serious? What should I do?
Thanks!!
Old Nov 18, 2010 | 06:21 PM
discoklein's Avatar
You don't need a horn, use the finger...ha ha
Old Nov 18, 2010 | 08:42 PM
Fireman's Avatar
First use DVM and establish you have voltage to horn. Then check fuse. Then check switch. Then check wiring. THEN give up and use finger... or install steel bumper.
Old Nov 18, 2010 | 08:43 PM
lipadj46's Avatar
You probably need to replace your horns
Old Nov 18, 2010 | 10:28 PM
lordmorpheus's Avatar
agreed. If you heard a faint horn sound once upon a time, then that went away, the horns have probably failed. Certainly wouldn't hurt to make sure you are getting 12V to them before buying new ones though.
Old Aug 8, 2011 | 01:20 AM
how long would it take to replace the horn? i need to get this done asap to pass the virginia safety inspection.
Old Aug 8, 2011 | 01:23 AM
Land Rover - Parts, Accessories and Information
There's a low note and a high note horn. Bizarre they both stopped working. FWIW I am still getting the very faint horn noise, but no one can hear it unless you're standing next to car. Wish I could attach an audio clip.
Old Aug 10, 2011 | 12:46 AM
What is DVM and how do I "establish (I) have voltage to horn."?
It's coming very faintly from the driver's side of the car. Nothing from the passenger's side at all.
Does this sound like a bad horn or a wiring/voltage issue?
Old Aug 10, 2011 | 01:40 AM
socalrovershop's Avatar
most common thing to go out on this subject is the buttons themselfs , faint noise can also mean slight contact. check the buttons out first
KlamathMatt
Mar 30, 2016 07:29 PM
Redd
Mar 8, 2014 05:14 PM
Billabong
54
Oct 6, 2009 02:31 PM
Chrisinhouston
Feb 25, 2009 06:15 PM
discodan
May 9, 2006 01:32 PM
