Rear alignment...
Old Aug 8, 2011 | 10:45 PM
superdiscovery's Avatar
Default Rear alignment...
Is correct to say the Discovery II (with air suspension) have an "individual alignment" ...? or for this rear suspension type, the toe will´be set on each rear wheel individually?
The (oldest) right rear tire have excess of toe-out and the shoulder was very damaged.
Thanks.
Edit: the tire damaged was on the rear right side...
Old Aug 9, 2011 | 06:40 AM
drowssap's Avatar
I could be wrong here (i was once before) but you have a solid rear axle there is no toe in or toe out adjustments.
Old Aug 9, 2011 | 10:30 PM
Ok.. and this terms, must be used on LR 3 for example ?...
I think this adjustments are related to air suspension...
Thanks drowssap.
Old Aug 10, 2011 | 01:44 AM
socalrovershop's Avatar
no adjustment on discovery due to like he said solid axel. LR3s have control arms and do have rear toe adjustment. the only adjustment in the rear for a discovery is the air suspensrion adjustment where you fit two blocks and use t4 to calibrate/adjust ride height. if you have wear in the rear maybe you have bent suspension components or worn bushings.
Old Aug 10, 2011 | 08:35 AM
A few months ago, a friend made a calibration with Rovacom and yes, the vehicle was an incorrect rear hights (more hight at left side, maybe 3-4 cms.)... and now reading your information I think it was the cause for that tire damage, the tire on the opposite.
Now, the rear hights are correct.
Thanks...
CANAMDiscovery
Jul 16, 2010 06:19 AM
DiscoII
Dec 3, 2007 05:18 PM
Waggy23
May 16, 2007 10:00 PM
Bubba_13
Sep 7, 2006 11:05 AM
jomeheretu11
Oct 31, 2005 06:55 AM
