Hose-clip tool?
Old 10-06-2014, 03:32 PM
twaszak's Avatar
Default Hose-clip tool?
What kind of tool is used to install the Land Rover factory installed hose-clips?
I always replace them with whatever is readily available at the local parts store because I can't figure out how to reuse them etc.
I can see how they are handy for tight spots etc... I replaced a large one with a screw/worm drive hose clamp and the screw is about a 1/4 inch from the serpentine belt etc.
I found the part number for the hose-clip that secures the low pressure PAS hose to the PAS reservoir: QYC100240
I also uploaded a pic of one I removed.
Does anyone what type of tool is used for these types of hose clips?
Cheers,
Thomas
Old 10-06-2014, 03:40 PM
acamato's Avatar
I use a flat head screwdriver to remove and needle nose pliers to install.
Old 10-06-2014, 04:02 PM
sdhow's Avatar
NAPA used to sell a special crimping tool for use with "Oetiker" style clamps that works quite nicely.
Old 10-06-2014, 04:09 PM
ZGPhoto's Avatar
Buy this, it's amazing.
Amazon Amazon
Old 10-06-2014, 04:24 PM
Originally Posted by ZGPhoto
I agree but a tad pricey. I use an old pair of pincers ............ far cheaper
https://www.google.fr/webhp?sourceid...enters+pincers
Old 10-06-2014, 04:26 PM
ZGPhoto's Avatar
Completely different parts! The ones I linked allow you to do it easily one handed and makes the thermostat job a 10 minute one
Old 10-06-2014, 05:40 PM
cappedup's Avatar
Does that tool nip up the factory fitted style clamps the OP is talking about? I can see how it would hold open the t stat style clamps, which I've always done with mole grips. I agree that will be great for that type of clamp in hard places, but not sure it's what the OP was looking for.
I also have a bunch of jubilee clips I'd love to replace with better looking items. Never have liked them.
Old 10-06-2014, 05:51 PM
ZGPhoto's Avatar
Yes it does, the engagement end has 2 metal tabs at a 45 degree angle that compress at the bottom, they work great with this style clip
Old 10-06-2014, 06:03 PM
cappedup's Avatar
Ooh. Then I might invest. T stat coming up.
And if it was a dual purpose hose clip tool thingy, more to the good.
Thanks.
Old 10-06-2014, 07:25 PM
RicketyTick's Avatar
Thanks.
I take the small ones off like in the op's picture with needle nose and snap them back with the same.
The big ones on the coolant hoses, I take those off and put on the good stainless ones that oreilly carries (below). Easier to work with in a pinch like if you don't have a special tool with you. They are kinda pricey but will last forever.
But the special tool is handy when working on one that still has the old spring clamps.
Quick Reply: Hose-clip tool?
