Hose-clip tool?
Old Oct 6, 2014 | 03:32 PM
twaszak's Avatar
Default Hose-clip tool?
What kind of tool is used to install the Land Rover factory installed hose-clips?
I always replace them with whatever is readily available at the local parts store because I can't figure out how to reuse them etc.
I can see how they are handy for tight spots etc... I replaced a large one with a screw/worm drive hose clamp and the screw is about a 1/4 inch from the serpentine belt etc.
I found the part number for the hose-clip that secures the low pressure PAS hose to the PAS reservoir: QYC100240
I also uploaded a pic of one I removed.
Does anyone what type of tool is used for these types of hose clips?
Cheers,
Thomas
Old Oct 6, 2014 | 03:40 PM
acamato's Avatar
I use a flat head screwdriver to remove and needle nose pliers to install.
Old Oct 6, 2014 | 04:02 PM
sdhow's Avatar
NAPA used to sell a special crimping tool for use with "Oetiker" style clamps that works quite nicely.
Old Oct 6, 2014 | 04:09 PM
ZGPhoto's Avatar
Buy this, it's amazing.
Amazon Amazon
Old Oct 6, 2014 | 04:24 PM
OffroadFrance's Avatar
Originally Posted by ZGPhoto
I agree but a tad pricey. I use an old pair of pincers ............ far cheaper
https://www.google.fr/webhp?sourceid...enters+pincers
Old Oct 6, 2014 | 04:26 PM
ZGPhoto's Avatar
Completely different parts! The ones I linked allow you to do it easily one handed and makes the thermostat job a 10 minute one
Old Oct 6, 2014 | 05:40 PM
cappedup's Avatar
Does that tool nip up the factory fitted style clamps the OP is talking about? I can see how it would hold open the t stat style clamps, which I've always done with mole grips. I agree that will be great for that type of clamp in hard places, but not sure it's what the OP was looking for.
I also have a bunch of jubilee clips I'd love to replace with better looking items. Never have liked them.
Old Oct 6, 2014 | 05:51 PM
ZGPhoto's Avatar
Yes it does, the engagement end has 2 metal tabs at a 45 degree angle that compress at the bottom, they work great with this style clip
Old Oct 6, 2014 | 06:03 PM
cappedup's Avatar
Ooh. Then I might invest. T stat coming up.
And if it was a dual purpose hose clip tool thingy, more to the good.
Thanks.
Old Oct 6, 2014 | 07:25 PM
RicketyTick's Avatar
Thanks.
I take the small ones off like in the op's picture with needle nose and snap them back with the same.
The big ones on the coolant hoses, I take those off and put on the good stainless ones that oreilly carries (below). Easier to work with in a pinch like if you don't have a special tool with you. They are kinda pricey but will last forever.
But the special tool is handy when working on one that still has the old spring clamps.
