Hot Shot to clean tappets?
This product is made to clean hydraulically actuated injectors (HEUI) in diesel engines; specifially to eliminate "stiction" (where oil deposits/varnish clog the small oil passages in the injectors): The Original Stiction Eliminator - Hot Shot's Secret
Has anyone tried this to clean or free up sticking (ticking) tappets in our flat tappet cam followers? I believe some HAVE used the Lucas Oil Stabilizer in this manner.
actually hot shot works ok ...I have used it in diesels ...but what is alot better is revx but its expensive it was made specificly for ford/international diesels and the stuff actually works I used it in my disco and it quieted down the valve train huge time and my 4.0 has the low oil pressure issue I put this stuff and even with the low oil pressure it is quiet ...I own a shop that does alot of ford powerstroke diesel work and the stuff is amazing on ford injectors has actually saved customers from having to replace faulty injectors ...just my .02 cents
Drop me a line at sdhoward at parker dot com
mouse
Nov 18, 2014 05:20 AM
Rimmer
Nov 3, 2012 01:13 AM
johnboyairey
Oct 15, 2008 06:16 PM
