How to Change the Purge Valve...
Old Sep 17, 2012 | 07:24 PM
Jared9220's Avatar
Default How to Change the Purge Valve...
I'm leaving this forum and have deleted all my work in this thread.
Old Nov 5, 2012 | 08:30 AM
WBMIAMI's Avatar
4th Gear
Hi
GReat tips. Would this be the same AutoZone part# and instructions for a 2004 D2?
Thanks!
Old Nov 5, 2012 | 02:14 PM
primussucks's Avatar
Did your p0441 go away after the replacement?
I've also read the Hyundai part number works as well.
Old Nov 5, 2012 | 02:31 PM
ZGPhoto's Avatar
I used the hyundai part and my CEL went away.
Old Nov 5, 2012 | 03:17 PM
pinkytoe69's Avatar
Assuming I can finagle the tubing to fit, you guys think I can I can use this on a D1?
Old May 16, 2013 | 11:20 AM
Zonk872's Avatar
Can I use this on a 03'?
Old May 20, 2013 | 11:24 AM
Normd996's Avatar
Will this purge valve issue/code have an effect on the gas mileage?
and will this MOD work on the 03-04 D2
Thanks
Old May 20, 2013 | 11:44 AM
ZGPhoto's Avatar
This isn't a mod, this is a failed part replacement. You shouldn't notice any difference.
Old May 20, 2013 | 12:00 PM
Zonk872's Avatar
Autozone Part#911-800 worked great as the replacement for my 03' D2. Back to smooth idle and the code stopped showing up. I managed to release the stock hose clips with a small flat screwdriver and re-clamp it with a pair of pliers (not standard).
Old Oct 16, 2013 | 12:45 PM
rmcshaffry's Avatar
Thank you in advance for this thread...am off to buy this part now!
