How to check ATF level 1 day after jo b done
on
1 Post
Guys, Did the auto tranny filter change job yesterday, and now I'd like to check if the fluid level is good. How do I procede??? Is it as simple as just removing the oil filler cap when the engine is cold and not running, or do I have to go trough all the circus of starting the engine and going trough all the gears...... My Rave CD has a procedure for the fluid check of the t-case and manual gear box, but no procedure to check the auto gear box.
Thanks,
Darover.
Thanks,
Darover.
on
1 Post
RE: How to check ATF level 1 day after jo b done
Cause although the dealer had a record of a tranny service at around 20 000 miles, they could not confirm that the filter changehad ever been done. And by the looks of the filter, I doubt it. It was covered in residue.
Anyways, dropped the pan, changed the filter and filled with Mobil1 synthetic ATF. Reason for asking today, is that the truck has been sitting overnight and is now cold. Not knowing better, I dove under and removed the fill plug to see if the level was right (since I had done the job at a friend's garage and hadn't seen the amount of oil going in, since I was the one in the truck. all I know, is that he forced the last amount in with a tube filler, and hurried in installing back the filler nut. So I was afraid to be over filled). So I removed the filler plug, and it started pouring the size of a finger, like not just leaking out. So I panicked and reinstalled the filler nut and am now wondering if it was overfilled, or did I just remove too much by not checking the fluid in proper procedure.
on
1 Post
So if I get this right, when doing the initial fill up, you have to do it while the engine is running and the tranny is cold, by not running it during the fillup, but by applying the brakes and going trough the gears. And thereafter, when checking the level, the transmission has to be warm, in parkwith the engine running. Am I getting this right??
Also, how warm does the tranny fluid get ?? wouldn't want to get burned.
thanks again!
thanks again!
If the engine is not running, the oil will not be circulating, so most of the atf is sitting in the pan. That is why when you pull the filler plug about 2 quarts will pour out. Allautomatics must be checked with the engine running and in park (shifting through the gears helps circulate the atf). This gives youa measurement of the amount of atf in the whole transmission, not just what dumped back into the pan.
I just changed the fluid in my LR yesterday. I filled the pan with the engine running until a 2mm bead (a big spagetti string) started pouring out of the filler hole and then put the plug in. Temperature usually makes a difference, but I'm not sure how much... I only idled the engine for maybe 5 minutes when I topped it off. On my mercedes, the atf temp. has to be right at (I think) 70 degrees C when you check it....
Oh yeah, doing the intital fill up, I would fill the pan first with the engine off until it starts running out the hole (about 4 quarts), then add the rest with the engine running (about 2 more quarts) and run through the gears.
Does the atf need to be at operating temp (about 20 min. of driving)to check it correctly? Seems like checking it cold would result in too much fluid, which is usually worse than too little...
on
1 Post
All right, went for a 20 minutes highway ride and then got home, left the engine running, put the tranny in park and removed the filler nut.
I had a nice little flow of oil coming out, so I re-installed the filler nut and am calling it done. That oil does gethot though, cause when I removed the nut, with my luck, the washer fell on the ground and I had to cover the hole with my finger to avoid losing too much oil. OUCH! anyways, I don't think I ever put a washer on a nut that fast beforeand single handedly I might add.
Still wondering about the oil level though. Cause all together, that makes approximately 4 liters ( 4.2 quarts) to refill the tranny after a filter change. 2 quarts when cold to fill the oil pan, and another 2.5 quarts to fill ( some of it forced) while the tranny was cold with the proper procedure( going trough gears with foot on the brake) and then the amount that was dropped when I checked it this morning.
So can someone confirm that after a 20 minutes highway ride and checking itupon arrival wwith the trannyon park while the engine is still running and having a consitant 1/8 inch flow of oil comong out the fill holemeans the level is perfect.
Thanks again. You know, I've learned with these vehicles and all others for that matter, that your better off asking 2 to 3 times, than assuming and end up with humongus problems. Especially when out of warranty.
Thanks again.
Thanks again.
