How deep of trouble am I in?
Old Apr 4, 2013 | 06:35 PM
wreckdiver1321's Avatar
Unhappy How deep of trouble am I in?
The shop popped the heads of the engine today. The driver's side rear cylinder is clean. I couldn't find where the gasket might have blown, but I don't really know what to look for. Am I in bad shape?
Old Apr 4, 2013 | 06:55 PM
dr. mordo's Avatar
Possibly. There's a coolant passage next to the cylinder, and a failing gasket could allow coolant into the cylinder.
Or you could have a cracked liner.
Old Apr 4, 2013 | 07:11 PM
ZGPhoto's Avatar
You have less of a bad liner possibility due to the fact it's a 4.0, but it's still possible. Could be a slight warp I suppose. I'd say get the heads planed and get a new head gasket in there and call it a day.
Old Apr 4, 2013 | 08:09 PM
94svt50's Avatar
Its usually one of the interior cylinders that crack behind the liner, they have the thinnest tolerances between the water jacket.
Old Apr 4, 2013 | 08:55 PM
Okay cool. That's my plan.
Old Apr 4, 2013 | 10:35 PM
taylor15's Avatar
What symptoms lead to having the covers pulled?
Old Apr 4, 2013 | 10:37 PM
It was using up a bit of coolant. I decided I didn't want to take any chances and give myself some peace of mind.
Old Apr 5, 2013 | 12:15 AM
Here's a pix of a blown out gasket, you can see that the gasket is just extra thin around that water channel. Always have heads checked to determine if you skip machining, usually you can't.
Old Apr 5, 2013 | 08:03 AM
ZGPhoto's Avatar
Mine was nowhere near as bad, I could barely notice it(though it was barely leaking coolant). They don't all look like that!
Old Apr 5, 2013 | 08:17 AM
Very true, this one was a "gusher" external. But it illustrates the slim design of the gasket at the coolant channel.
