How do I confirm CDL is locked? (light isn't lit)
Old Nov 15, 2013 | 01:57 PM
acamato's Avatar
Default How do I confirm CDL is locked? (light isn't lit)
I installed a 04 CDL shifter a few months ago. I never checked the switch when i have to console and cover plate off. The light doesn't light up when the shifter is engaged. It could be two things: the switch or the cable isn't moving the lever enough.
Is there a way to determine if the CDL is locked w/o taking the console and cover plate off?
Old Nov 15, 2013 | 02:04 PM
dusty1's Avatar
just manually engage from below?
Old Nov 15, 2013 | 04:09 PM
Externet's Avatar
Exclamation
Idling in neutral, with only the front or the rear axle barely lifted off the ground, the vehicle will jump/drop off the stands if the central differential is locked when shifted to D. Be careful !
If unlocked, only the lifted axle wheels will turn.
Old Nov 15, 2013 | 04:23 PM
jafir's Avatar
Sometime the light won't come on until you drive a few feet. My D1 and Defender both act that way.
Either way, your steering will feel heavy when it's locked.
Just lock it while on a paved road or parking lot, put it in reverse, crank the wheel all the way to the stop, and floor it. If a CV joint blows up, you'll know the CDL is working.
Old Nov 16, 2013 | 12:25 PM
acamato's Avatar
I pulled off the center console and plate this morning. I disconnected the cable from the lever in the nipple and engaged the cdl. No light, so I backed down (straight) the driveway and pulled back up. Still no light. I then pulled the connections off the diff lock switch and sprayed them with brake cleaner. Still no change. I am going to order a new switch.
Old Nov 16, 2013 | 12:54 PM
ZGPhoto's Avatar
Sometimes I can't get the light on/off without driving in a few tight circles.
Old Nov 16, 2013 | 01:18 PM
Externet's Avatar
Originally Posted by acamato
...disconnected the cable from the lever in the nipple and engaged the cdl. No light,... I then pulled the connections off the diff lock switch and sprayed them with brake cleaner. Still no change. I am going to order a new switch.
Check continuity of the switch in both positions to confirm the switch is the problem before ordering/replacing.
Old Nov 17, 2013 | 09:07 AM
acamato's Avatar
Thanks Zach, I will find a dirt or gravel area where I can give this a try. I am worried about breaking something if I try on pavement.
Old Nov 18, 2013 | 06:32 AM
jfall's Avatar
I had an RR where the central diff was always locked due to the viscous coupling being bad.
When I put the steering wheel all the way to one side or the other and drove a tight circle on pavement - the tires would chirp on the pavement.
Old Nov 18, 2013 | 08:43 AM
dusty1's Avatar
good call. I hear a chirp as well, when i (oops) am engaged and clocked in tight circle on finished roadway.
I have forgotten to disengage more than a couple of times at the ranch. I've gone down the blacktop a bit before noticing.....never broke anything
