How do I open the hood from outside the cab?
Long story short I have a mystery power draw somewhere killing the truck overnight. With the truck locked, and the design of the truck, that means I’m locked out.
which means I can’t pop the hood easily to jump the truck and unlock it.
is there a way to easily pop the hood from outside the cab?
EDIT: after googling, I can’t find out what the starter looks like, how to find it, let alone the positive post. Any help in that regard?
The srarter is on the pasenger side of engine, near bell housing, behind exhaust manifold, pull heat shield back (aluminum cover), clips on partially, and attach battery charger to positive post and negative to a good ground.
Door locks are electric, need voltage...even when using key in drivers door.
lostmonster (02-05-2022)
That is not correct. The key in a properly functioning door lock will unlock the driver door regardless of whether or not the battery is charged. Try it.
So which is it?
when I first tried it, it felt so locked in place that turning was going to break it again. If I’m unable to figure out the starter, I’ll try it again gently.
