How to get this out , d2a td5
Old Dec 2, 2020 | 06:42 PM
buzzliteyeh's Avatar
Default How to get this out , d2a td5
Hi a bolt has fallen in where the timing chain runs and is at the bottom , can I get to it by dropping the oil Catch or will I have to take the timing chain cover off as well
The small bolt/screw is at the bottom left ,beside the cog
Looking down it's on the right hand side next to the bottom cog/sprocket . Any advice and laughter accepted .
Last edited by buzzliteyeh; Dec 2, 2020 at 06:43 PM. Reason: Adding Make and model
Old Dec 2, 2020 | 07:15 PM
sodaparis's Avatar
retrieval tool would be worth a shot, either the type pictured below or a magnetic telescopic one, should be available locally
Old Dec 2, 2020 | 07:18 PM
Thanks for the reply , I've given the two that I have here a go and they are just too big ...
Old Dec 2, 2020 | 08:34 PM
gecko951's Avatar
Couple of ideas...
1. If you have a magnetizer then find a small diameter, bendable steel rod, magnetize the end and go fishing.
2. Find small diameter tubing that can reach the hardware and attach it to your shop vac with duct tape and the suction should be able to grab the bolt.
Old Dec 2, 2020 | 08:48 PM
Mate i didn't even think of a vacuum ! I've just epoxied a magnet to a clothes hanger wire and will see how i go , but the vac will be the next idea
Old Dec 2, 2020 | 09:00 PM
nashvegas's Avatar
This is how the Defender guys do it
Sorry, I am of no help.
za105
Apr 6, 2016 02:38 PM
SWAINROVER
Mar 18, 2016 05:26 AM
shezm
Mar 29, 2013 06:30 AM
LRScott
Jul 29, 2012 01:52 AM
DooDer
Jan 1, 2010 02:26 PM
