How hot is too hot?
on
Between the radiator and your after market cooling fan, you are slowly killing your engine. Once you hit the 230 range you are in trouble.
I would suggest you replace the radiator, t/stat, find a good used factory fan and throw in a bottle of Water
The aftermarket fan is the same diameter as the old, could the cfm really be that different? It's time to replace the radiator anyway, had a pinhole leak I temporary fixed with jb weld. The stat is the new soft spring unit, it runs 186-194deg in 90 deg heat on the open road . It just keeps creeping up as soon as you sit at idle.
I don't have a temperature issue - relatively new T-stat, water pump, fan, etc. Monitor occasionally with an aftermarket interface and iPhone and temp never exceeds 210 - I guess this is O.K. for a southern summer.
Question - are these lower temp thermostats direct replacements for OEM unit? I don't want to fix something that's not broken, but if this is an easy direct swap, why not?
DRW
DRW
