How hot is too hot?
Old Jun 25, 2012 | 08:07 AM
Originally Posted by 94svt50
Thanks for all the replys, I will check the radiator with a infrared thermostat and see if there is any temp difference between top and bottom. When I changed to the gray thermostat it dropped temps alot, but it made no difference at the long idles with a/c on.
For what it is worth, with your mileage, you radiator is at least partially restricted from top to bottom because of the very thin veins and calcium build up.
Between the radiator and your after market cooling fan, you are slowly killing your engine. Once you hit the 230 range you are in trouble.
I would suggest you replace the radiator, t/stat, find a good used factory fan and throw in a bottle of Water
Old Jun 25, 2012 | 10:19 AM
94svt50's Avatar
The aftermarket fan is the same diameter as the old, could the cfm really be that different? It's time to replace the radiator anyway, had a pinhole leak I temporary fixed with jb weld. The stat is the new soft spring unit, it runs 186-194deg in 90 deg heat on the open road . It just keeps creeping up as soon as you sit at idle.
Old Jun 25, 2012 | 11:38 AM
94svt50's Avatar
Where is the best place to buy a new radiator? AB has them for around $315 for whatever brand they carry.
Old Jun 25, 2012 | 11:49 AM
DiscoRover007's Avatar
They sell new radiators on ebay for $159 with lifetime warranty, not sure if those are junk or not though.
Old Jun 25, 2012 | 12:45 PM
Eaglerover22's Avatar
Is it unbecoming to brag about my 183.8/194 idle temps on my original T-stat?
Old Jun 25, 2012 | 04:15 PM
94svt50's Avatar
Sounds like your stat is stuck open.
Old Jun 25, 2012 | 06:42 PM
ebg18t's Avatar
Just ordered a new radiator (hella behr brand) from Lucky8 today. $210 shipped.
Old Jun 25, 2012 | 08:45 PM
94svt50's Avatar
thanks, that sounds like a good deal.
Old Jun 25, 2012 | 10:07 PM
oilspotLR's Avatar
Originally Posted by street wolf
224 is by no means normal at any length of idling. 224 is too hot no matter what the situation is and nowhere close to acceptable. Mine doesn't top 210 under a heavy load at low speeds in 110+ texas heat.
^^agree^^
Old Jun 26, 2012 | 08:22 PM
DonRW2007's Avatar
Default My temps O.K. but...
I don't have a temperature issue - relatively new T-stat, water pump, fan, etc. Monitor occasionally with an aftermarket interface and iPhone and temp never exceeds 210 - I guess this is O.K. for a southern summer.
Question - are these lower temp thermostats direct replacements for OEM unit? I don't want to fix something that's not broken, but if this is an easy direct swap, why not?
DRW
