How to install castor corrected arms?
Old May 8, 2017 | 04:23 PM
Jeff Blake's Avatar
Default How to install castor corrected arms?
Having trouble aligning the 2 bolt holes on each side from arm to axle. I suspect the axle needs to be rotated backwards a bit - makes sense since this is to correct the castor... the question is, how?
I tried jacking the front edge of the axle
pry bar
The frame is jacked up, axle supported lightly by a jack. Wheels off ground.
What next?
Old May 8, 2017 | 04:43 PM
Jeff Blake's Avatar
OK scratch that
I thought I read somewhere to do the frame bolt first, then axle. Doesn't work. Do axle bolts first, then the frame. Good to go!
Old May 8, 2017 | 09:48 PM
shady milkman's Avatar
Honestly when I did it it seemed fairly easy, but the guy that I got them from said he spent a day taking them off. I put my frame on jack stands and the front axle on a 5000 pound jack. Popped the bolts off and the arms fell right off. When I put the new ones on I put the front two bolts in first then the bolt on the rear of the arm. Used my feet to push the axle back in place so that rear bolt aligned and wiggled it in. Took about 2-3 from start to finish. Mine are the qt 3 degree arms.
Old May 8, 2017 | 09:50 PM
Jeff Blake's Avatar
Sounds about right. The whole job was pretty painless. The hard part was getting those bushings in.
Don't forget to check your springs before dropping the frame... both my springs popped out of the upper mounts. Oops
Alex_M
Apr 12, 2017 01:45 PM
coors
Jan 4, 2017 08:51 AM
humroot
May 27, 2016 02:03 PM
cybercop
Jan 28, 2015 11:23 AM
welling4x4
Sep 29, 2010 11:15 AM
