How to install a new head gasket on a 4.6 liter
Old Oct 3, 2018 | 03:18 PM
Texasplumber's Avatar
6th Gear
Default How to install a new head gasket on a 4.6 liter
Old Oct 3, 2018 | 03:27 PM
R0VERGUY's Avatar
I think that raised collar is to help line up the gasket and head and it's like that on all D2 motors and not something that failed on yours in particular, I think. It should fit inside that bolt hole in the head just fine and sit flush once installed.
I love your enthusiasm in your video. Good ole Texas boys! I'm just south of San Antonio in Floresville, Tx if you ever need anything.
Old Oct 3, 2018 | 06:38 PM
6th Gear
Default Question
Why was it only on the driver side? I hope you liked the vide otherwise.
Old Oct 3, 2018 | 06:46 PM
Charlie_V's Avatar
Longview, TX here.
I remember collars on both sides for the gaskets. Be sure to check carefully that nothing ( collars ) has fallen in your cylinders... I started an engine with an unseen bolt in a cylinder and it was no bueno.
Clean engine. Looks nice. I like your video.
Old Oct 3, 2018 | 07:32 PM
CollieRover's Avatar
If it was a timesert it was meant to sit flush.
Inlike the video. We need more Doug tho. Wealth of knowledge.
Old Oct 3, 2018 | 09:23 PM
6th Gear
Originally Posted by Charlie_V
Longview, TX here.
thank you very much I’ll remember that next time.
Old Oct 3, 2018 | 09:25 PM
6th Gear
Longview, TX here.
Doug is a great friend to have, we have worked on more stuff than I can count. Thank you for the advice!
Old Oct 3, 2018 | 09:29 PM
6th Gear
It seemed like it was out of place because there was nothing similar to it anywhere else on the block surface. I appreciate the advice and I’m sure I’ll have questions down the road so I’ll keep you in mind.
Old Oct 3, 2018 | 09:32 PM
R0VERGUY's Avatar
Yeah I could be wrong about it being there to help line up the gasket, it has been 90kmiles and 4 years since i had my heads off, but I could have sworn I remember there being something like that on my block also to hold the gasket in the correct position while installing the heads.
Old Oct 3, 2018 | 10:29 PM
mollusc's Avatar
I have the heads off my 4.6L right now. There are two collars on each side to act as guides for the gaskets and the heads.
