How much coolant does your disco drink?
Old Jun 17, 2019 | 12:45 PM
mr. choodles's Avatar
Default How much coolant does your disco drink?
Need to top off mine every 3-4K miles with 100ml. No leaks on the ground. No apparent leaks under the hood. No coolant smell. Is this normal?
120K on the clock, 2004 Disco 2. All coolant hoses, vacuum leak hoses, and other rubber/plastic hoses have been replaced.
Old Jun 17, 2019 | 02:06 PM
Richard Gallant's Avatar
Check under the throttle body heater, when you park at home, put a paper towel on the valve cover. My bet is it will have a wet spot the next morning.
Also try the same around the throttle body heater gasket paper towel and pad around the outside, to check for dampness.
That area tends to leak very slowly and the amount sounds right. It is hard to find because the small amount evaporates off fast
Old Jun 17, 2019 | 03:07 PM
Big Jim Swade's Avatar
I'd say that is pretty good. I loose 100ml probably every 1,000 miles. Been that way since I bought mine in 2011.
Old Jun 17, 2019 | 05:37 PM
redwhitekat's Avatar
Should not drink at all It’s a air tight system
you have a leak
Old Jun 17, 2019 | 06:13 PM
Extinct's Avatar
Yeah, you have a leak, internal most likely. Crack your bottle cap 1 turn and it should slow down.
Old Jun 17, 2019 | 06:36 PM
Discorama's Avatar
Close to zero.
Old Jun 17, 2019 | 11:25 PM
User's Avatar
None at all over 20k miles. I bypassed the TBH and will install a new one when I make a large order of parts. Maybe next year or two.
Old Jun 18, 2019 | 07:35 AM
Thank you, will test today. If it is a leak TBH leak, is the fix as simple as installing a new plate kit (https://www.roverparts.com/Parts/MGM000010KIT)?
Old Jun 18, 2019 | 10:10 AM
Dave03S's Avatar
Yes, but be meticulous about installing it and its gasket. If you see no signs of leak there just do a simple pressure test.
Old Jun 18, 2019 | 10:13 AM
CollieRover's Avatar
Autozone rents the pressure tester, so a no brainer.
If it is the Throttle Body heater get a genuine kit, the Britpart kit stinks to install. I resurfaced mine with sandpaper, and it sealed very well. The surface of mine looked rounded. I remember someone skips the gasket and uses The Right Stiff the seal, but I have not and couldn’t attest to that.
