How much lift will I need?
Old Feb 7, 2009 | 10:26 PM
LCollins1990's Avatar
Default How much lift will I need?
I was wanting to lower my 04 but I don't guess they make a kit for it so how much lift would I need to fit a 35" tire?
Old Feb 7, 2009 | 10:30 PM
Camdisco24's Avatar
Default RE: How much lift will I need?
Most have todo a 3" lift to fit that size tire.
Are you doing it for looks or for off road?
EDIT: That was supposed to say three all along, NOT TWO.
Old Feb 7, 2009 | 10:43 PM
just looks for right now it came with 22s but no stock wheels
Old Feb 7, 2009 | 10:48 PM
Disco2Guy's Avatar
Why do you want 35" tires if you originally wanted to lower it??? There's no way a 35" will fit with a 2" lift. Most need a 3" just to fit a 285/75/R16 (32.8"). Once you hit 33", you need to start thinking about HD axles, and gearing, because of the extra weight and increased size. How much off roading will you be doing with it? Your mileage will suck with tires that big too.
Old Feb 7, 2009 | 11:03 PM
Because it's gonna cost too much to lower it and with a 22 I think that anything smaller than a 35 will be too low profile. And it will probably never see anything but asphalt i'm building a 96 for off road
Old Feb 7, 2009 | 11:24 PM
llesra's Avatar
youll need at least 3" of lift with a lot of cutting to stuff the tires
Old Feb 7, 2009 | 11:36 PM
pilsner's Avatar
im confused. do you want to lower your truck or lift it? are you intending to run 35" tires (as in 35x12 mud terrains or whatever) or do you mean 35 SERIES tires as in 205/35/18s? low profile performance type tires?
Old Feb 7, 2009 | 11:50 PM
Disco2Guy's Avatar
It sounds like he wants to fit a 35" tire to a 22" wheel.
How much does it cost to lower a D2? Have you priced how much a 3" lift costs? I'd put that money into the D1 where you'll have something functional and cool, instead of something that's supposed to look cool.
Old Feb 8, 2009 | 12:15 AM
Jupiter Rover's Avatar
You can lower a DII, just get big blues and they will sag in a week!
Old Feb 8, 2009 | 01:03 AM
hazletbassist89's Avatar
It's gonna need even more than a 3" lift. For a 265/75/16 (32 inch) you need 2 inches of lift. So for a 35 inch tire you will need about 5 inches of lift. The only 5 inch lift kid I've seen costs about $3,000 BEFORE new driveshafts. You may want to look into something smaller, these trucks really aren't built for that sort of application.
