How much smoke is normal?
Old May 3, 2018 | 04:14 PM
lrnoob's Avatar
Default How much smoke is normal?
Finally got her back up and running after the Head Gasket job. Let her run for a bit to warm up, but she started smoking a lot after a few minutes, so I cut it.
White smoke coming from the back of the exhaust, and tons of smoke coming from under the exhaust manifolds and around the cats. Is this just residual coolant burning off/out? It smells more like burning plastic, rather than anything sweet. I don't see anything rubbing any belts or moving parts.
Old May 3, 2018 | 04:46 PM
No Doubt's Avatar
Checking first that you don't have a fire problem, if you had coolant or oil in your exhaust before the head gasket job then it is expected to take 10 minutes or so to burn out that residual.
Of course, you want to insure that you aren't burning *new* coolant or oil, too.
Old May 3, 2018 | 05:11 PM
Saturnine's Avatar
MagPie smoked under the hood for a good 10-20mins burning off all the penitrating oils etc I had used after doing my HG.
Its possible to have some crud burn off in the chambers, did you clean them at all?
Old May 4, 2018 | 01:40 AM
lrnoob's Avatar
Yes, I cleaned up the tops of the pistons, but a few still had some gunk I couldn't get off.
I did use plenty of penetrating oils trying to get all the bolts and such off, so that would make sense, too.
lrnoob
May 3, 2018 11:22 AM
danvlarsen
Apr 24, 2013 04:09 PM
bothomasmusic
May 24, 2011 12:47 PM
CBK
Apr 2, 2011 10:07 PM
elboy0712
Feb 20, 2010 09:37 PM
