How to remove and paint a headliner from a D2
I was referring to areas in the actual fiberglass/foam headliner (under the felt material) that became deformed over time. I didn't remove the indentations that are formed into the headliner that are there for vehicles with sunroofs. The actual fiberglass/foam board was actually sagging across these "sunroof indentations". If you looked at the board from the side, you'd see a raised/bowed area of approximately 1/2" high.
When the headliner board was cleaned and wet, the board becomes highly flexible. During the drying period, I placed weighted objects in this bowed area and forced the board to dry against a flat surface. In short, you can take out a little warpage that you may have in the board when it is damp, during the drying period.
webshots turned into smile so im not sure whats going on trying to sort it out today for you mate
Okay the pics are working thanks hilltopper. Ran into a problem. Here it is.
So Everything has gone great and as it should. But in the back middle seat the dome light with the sunroof switch wont come out. I got the light and harness out but the sunroof switch is a pain to get at. I feel a thick wiring loom that is very stuff and also I feel metal like a bracket or something. Any ideas on how to remedy this? It is a 2001 SE Disco. No rear AC. Just the dome light and dual sunroofs. I tried pushing down on everything but it just moves the entire plastic construction as one. HELP! Thanks in advance.
Okay. Will feel for it tomorrow on sunrise. I'll inform as to what the outcome is.
