how to replace oil separator
Old Aug 26, 2012 | 08:52 PM
928paul's Avatar
Default how to replace oil separator
does anyone have photos how to replace oil separator? or please show me a link to the RAVE manual thank you very much
Old Aug 26, 2012 | 09:01 PM
PCV Kit - BOSCH Engine - Land Rover kits from Atlantic British
Passenger side valve cover, its the only hose going from the valve cover to the intake.
Remove the hose from the valve cover, remove the oil separator, clean with carb cleaner, put it back.
I always stick the carb cleaner straw into the hose and spray into it too.
Old Aug 26, 2012 | 09:37 PM
928paul's Avatar
how do I open that hose clamp? very tight can't move
Old Aug 26, 2012 | 09:42 PM
If it is one of the factory hose clamps cut it off with wire cutters or tin snips, whatever you have and then replace it with a worm clamp.
austinlandroverbill
Aug 23, 2015 01:03 PM
dougn
Dec 29, 2012 09:56 AM
kae
Jan 24, 2010 10:38 AM
sheelhorse
Jun 22, 2009 11:38 PM
discoboy
Feb 11, 2009 01:42 PM
