How to seal the secondary air exhaust leak??
Old Nov 25, 2011 | 01:16 PM
cobbcj7's Avatar
Question How to seal the secondary air exhaust leak??
Several attempts to solve my annoying exhaust leak have failed... I have found the problem to be in the connecting of the secondary pipes. It seems as if you don't get these perfect, it would be impossible to seal it off.
Could I make a gasket or something to put in there to stop the leak?
Do I need to buy a new set-up, which I dont want to do? or is there a trick to sealing it off??
Thanks again like always!
Old Nov 25, 2011 | 10:23 PM
coors's Avatar
Are you sure it's the SAI pipe? Where at? At the union nut/s?
Only asking because I had annoying leak which which I thought was a cracked exhaust manifold. I almost pulled the trigger on a set on Ebay, but decided to investigate further. Turns out the weld on my downpipe flange had cracked.
Moral here is make sure you check and double check. Can you hear or feel it leaking? You will also see a white carbon build-up.
Old Nov 26, 2011 | 12:50 PM
cobbcj7's Avatar
Im pretty sure thats the leak, since I have tried to fix it the noise is the same but louder.. and we did the SeaFoam smoke test and that seemed to be the spot of the smoke..
And yes the leak seems to be at the connection nut
EstorilM
May 8, 2022 12:39 AM
outdoor7or24
May 21, 2012 08:34 AM
yloDiscoII
Feb 10, 2010 10:03 PM
FordCrusherGT
Jan 10, 2007 02:15 PM
forbin10
Dec 21, 2005 06:51 PM
