I am stuck at the beach, help!
Old Jul 5, 2010 | 09:45 AM
99discoverysc's Avatar
Default I am stuck at the beach, help!
I have a 99 discovery 2. The front drive shaft is toast. I have the rear bolts off but I can't break the front ones loose(at the axle). The question I have is, can I tie the drive shaft off or does it turn with the axle gears? Are the front wheels engaged and is the shaft going to turn and break free of the tie off? I just need to get home and then I can put a air wrench on it.
Old Jul 5, 2010 | 10:00 AM
vandev's Avatar
Default i dont think so
That sucks,
I thnk the only way you can do this is if you have cdl like on a 04 and take the shaft completly off. and then lock the transfercase.... You should try private messaging Mike or Spike as they would know for sure..
Good luck, Chris
Old Jul 5, 2010 | 10:11 AM
lordmorpheus's Avatar
Correct. Even if you were able to get the front propshaft removed from the front axle, unless you have CDL, when you go to drive away, all power from the transfer case is going to be delivered to the front (least resistance) and the rear driveshaft will not turn.
What happened to the front shaft? Did it break? If it broke, did it do any other damage as these shafts are prone to doing?
Old Jul 5, 2010 | 10:18 AM
03discoman's Avatar
no worris....you have a CDL....just climb under and engage it
Old Jul 5, 2010 | 10:22 AM
I need more coffee, brain not up to speed yet. 1999 will have the CDL nipple, but I wouldn't trust tying the front shaft to something while it is still connected to the front axle.
Old Jul 5, 2010 | 10:38 AM
As mentioned, you do have a CDL t/case so get the front shaft off and feel about the front flange for a round plate held down with 3 bolts that has a shift nipple in the center of it. Turn it clock wise as far as it will turn and drive out carefully.
Old Jul 5, 2010 | 10:48 AM
Thank you!! I cant get the front bolts off in the field. Can I put the shaft back on at the t/case and still lock out the front drive shaft with the CDL? Thanks again!!!
Old Jul 5, 2010 | 12:04 PM
vandev's Avatar
Default you should be able to
I took mine off without rotating shaft. 2 on the bottom and two on top. get a closed end wrench and a 3/8 socket with swivel. It took me 40 minutes to get my front shaft out. It's a pain but possible. try some PB blaster or just saw the bolts off and get new ones.
Old Jul 5, 2010 | 12:50 PM
Engaging the CDL is not going to "lock out" the front drive shaft. It is going to lock the front and rear driveshafts together, essentially. Without engaging the CDL, if the front shaft is removed, only the front output on the transfer case is going to spin. With CDL engaged, both the front and rear output on the transfer case are going to turn at the same speed.
Old Jul 5, 2010 | 12:57 PM
handsome rob's Avatar
Sorry but you are going to need to get that front shaft off to get home.
