I can't seem to find the part
Hey guys. I am looking to have my front drive shaft U-joints replaced next week (1999 disco2 with 123k). I ordered three percision 344 u-joints but as I understand I need a centering/seal kit or something like that to go with them. I cant seem to track this part down through any of my sources (online/advanced auto/local auto shops). Can someone please lead me in the right direction. I appreciate it.
on
RE: I can't seem to find the part
While we are on this subject, I would recommend if you haven't done a u-joint jobbefore, or if you have never dismantled and re-assembled the double u-joint(Hookes joint)on the front shaft, you take your driveshaft to a pro. I took mine to a local machinist that does the work, the nearest drive shaft joint is an hour away.
I marked all of my parts so I'm not worried about disrupting the balance. I don't know if the added grease fittings on theHookes joint u-joints are enough to throw off the balance or not, I asked him to offset them to avoid any issue.
I worked on it all Saturday, and it was a pain, even with a bearing press. The local auto craft shop doesn't even touch the Hookes joint, and once I had it apart I figured I wasn't either. The machinist is charging me 100 dollars for the work and the parts are about 75 from Federated, all precision parts. Except the centering kit, he couldn't find it, so I gave him the Neapo one I had. The craft shop claimed precision is better, so you will be doing well with that.
I wish I had just takenthe shaftto him in the first place, because my Saturday is definitely worth more than a hundred bucks!
nick_m3
11-07-2014 08:38 AM
killerbeez
05-20-2013 05:08 AM
