I can't seem to find the part
Old Oct 13, 2007 | 02:17 PM
starcraft's Avatar
Default I can't seem to find the part
Hey guys. I am looking to have my front drive shaft U-joints replaced next week (1999 disco2 with 123k). I ordered three percision 344 u-joints but as I understand I need a centering/seal kit or something like that to go with them. I cant seem to track this part down through any of my sources (online/advanced auto/local auto shops). Can someone please lead me in the right direction. I appreciate it.
Old Oct 13, 2007 | 04:12 PM
Default RE: I can't seem to find the part
Then go to Car quest and get their 1-0005 joints and order their centering ball kit.
Old Oct 14, 2007 | 06:50 PM
starcraft's Avatar
This might be a dumb question but can you mix and match the parts? For instance can I put the Neapco ball kit from car quest in with the Precision 344 u-joints that I ordered?
Old Oct 15, 2007 | 12:37 PM
jwfuller's Avatar
Yes, you can. Did you find the centering ball kit? If not I can get you the Neapo part number. Are you doing the work yourself or are you getting someone to do it for you?
Old Oct 15, 2007 | 01:42 PM
jwfuller's Avatar
While we are on this subject, I would recommend if you haven't done a u-joint jobbefore, or if you have never dismantled and re-assembled the double u-joint(Hookes joint)on the front shaft, you take your driveshaft to a pro. I took mine to a local machinist that does the work, the nearest drive shaft joint is an hour away.
I marked all of my parts so I'm not worried about disrupting the balance. I don't know if the added grease fittings on theHookes joint u-joints are enough to throw off the balance or not, I asked him to offset them to avoid any issue.
I worked on it all Saturday, and it was a pain, even with a bearing press. The local auto craft shop doesn't even touch the Hookes joint, and once I had it apart I figured I wasn't either. The machinist is charging me 100 dollars for the work and the parts are about 75 from Federated, all precision parts. Except the centering kit, he couldn't find it, so I gave him the Neapo one I had. The craft shop claimed precision is better, so you will be doing well with that.
I wish I had just takenthe shaftto him in the first place, because my Saturday is definitely worth more than a hundred bucks!
nick_m3
Nov 7, 2014 08:38 AM
DonRW2007
Jan 6, 2014 09:19 AM
killerbeez
May 20, 2013 05:08 AM
stuart_hayes
May 2, 2013 04:38 PM
indys2k
Nov 13, 2007 08:39 AM
