I cross-threaded the line on my ABS for RR
Old May 10, 2017 | 04:58 PM
Mskembo's Avatar
Default I cross-threaded the line on my ABS for RR
So I did the optional 3 Amigos fix and somehow I cross-threaded the hardline for RR into my ABS unit. Give it to me straight guys, how screwed am I?
Edit: Another question, better to tap it or to drill it out and helicoil it? Anyone know what the stock fitting's threads are?
Old May 10, 2017 | 05:46 PM
Luckyjayb's Avatar
you shouldn't have had to take off any lines
Old May 10, 2017 | 06:33 PM
Mskembo's Avatar
I know, I tried to do it propped up with a 2x4, but the one closest to the front was really hard to undo. I think I'm just going to replace the whole thing.
Old May 11, 2017 | 03:26 AM
Luckyjayb's Avatar
Hope u have a pull a part close or can find a good one on eBay BC everywhere else ain't cheap. $600+
Old May 11, 2017 | 08:08 AM
Mskembo's Avatar
I found a used one for $50, so I think I'm going to go that route. Also I found them for $395 here 1999-2004 Discovery II Anti-lock Brake System (ABS) Modulator
Old May 17, 2017 | 12:20 AM
Mskembo's Avatar
Just a quick update. Abran had an ABS block that he sold me and didn't know the condition of the Shuttle Valve so I ordered a new shuttle valve from Lucky8. The one from Abran arrived and worked like a champ. 3 Amigos are gone and after the longest bleed of my life she is running (and braking) properly.
Old May 18, 2017 | 05:29 AM
OffroadFrance's Avatar
With Abran's help it sounds like you are on a winner.
Double check the codes and then clear all of the codes in the SLABS unit if the problem re-appears.
Old May 18, 2017 | 10:45 AM
Mskembo's Avatar
So far no new codes ABS codes and the 3 Amigos haven't come back yet either. Now time to address all of the other stuff!
Chadley
May 2, 2016 05:41 PM
JerrodSteph
Jun 12, 2011 06:04 PM
Phototone
Apr 4, 2008 10:26 PM
cbrantner
Sep 29, 2007 07:37 PM
