I finally figured out the reason for my front end issues
I was changing my fluids today (Oil, ATF, transfer case and differentials) and while flushing my brake fluid I noticed I have a broken left front spring. My left front side is sagging about 3 inches lower due to this. I probably should have noticed this earlier but I was not looking at the suspension.
I was having uneven tire wear and a little wheel shake (probably due to this and a shot steering damper). I was thinking of doing my suspension and now this seals the deal.
I think I am going with OME shocks and springs. Can anyone describe the difference between the heavy and Medium OME springs?
HD springs will be for lots of extra weight, winch, African elephant, etc.
MD would be for everything else.
The springs are what holds the weight of the truck, the shocks control the ride.
So the HDier the springs the stiffer the ride.
Same thing with shocks, HD ones will be stiffer than MD ones.
Now is the time to plan ahead, what do you think you may add to your truck down the road?
Also in theroy HD springs will last longer because they are stiffer to start with.
Yeah lucky 8 is where I will be getting them from. So are there any specialized tools I need to do this? Anyone have any links to old threads about installing new shocks and springs?
2008 Range Rover
supercharge
Front end just went down as i was driving minutes later sign blinking suspension will rise soon as cools down .
So i didnt drive it for 2 days & when i did it rised for a bit & went back down after drivibg it for about 30 min. Is there anything you can recommend i do & is it save to drive with it down ?
supercharge
Rovin4life
Off Topic
Sep 7, 2011 07:27 PM
Snafu / Disco Fries
Jan 28, 2011 01:42 PM
elboy0712
Dec 19, 2010 02:38 PM
