I have no idea about removing water pump gasket.
A razor blade and some steel wool or fine grit sand paper.
Use the razor blade to remove as much as you can and then the sand paper to finish it off and make it clean.
Then spray the whole gasket area with carb cleaner, let it dry and get back to work.
outdoor7or24
12-22-2014 09:31 PM
Marni
06-22-2013 05:04 PM
collin Barrows
Audio/Visual Electronics
08-22-2011 10:22 PM
