I must be crazy - 2004 SE7
Well, a day after my oil light decided to stay on, I stumbled upon a 2004 SE7 with 90,000 miles on it at a lot in Cincinnati and I nearly bought it. Everything works but I have some apprehension. I noticed lots of little yellow paint marks and black marker marks all over the engine and the coolant has been switched over to the green stuff. I think that the engine has been replaced. Has magnecores and the body is in great shape. SES light is on and the mech on the lot pulled the codes and came up with a lean bank left 02 code according to his scanner. They are asking 8900 for it which is about $2000 less than any other 03 or 04 in the Dayton-Cincy area. There is a Rover delaer down the road from this lot. Should I take it to them for an inspection?
What do you guys think? should I continue to pursue or should I run?
-aaron
2003 se7
already spent $8000 in repairs in 2 years
and now have oil warning light on........
-aaron
2003 se7
I thought the '03s with the oil pump problem had an inherent design flaw with the engine block that can not be fixed without replacing the block?
If I were in your shoes, I would replace the existing oil pump in your current disco (if your disco's vin is in that range) and trade it for the 04.
A brand new 4.6 here in the US is $7500.
A used one will be less of course depending on miles and condition.
And then he would have to be careful not to get sold another '03 engine, and with the '04 and '03 using the same engine if it were out of the truck already how would you know?
ECL
08-23-2006 06:50 PM
dherbs85
01-10-2006 07:55 PM
jasongilliland
08-29-2005 06:59 PM
