I need some advice.
Old Feb 27, 2011 | 09:03 AM
GEL's Avatar
GEL
Default I need some advice.
I have a 2001 discovery SE. About 2 years ago we had the heads shaved and all the gaskets replaced. 2 months ago the top hose blew. I had it replaced. 2 days ago it began to overheat and it blew out all the coolant. I had it filled and checked for leaks. there were no leaks. Then I replaced the T-stat. It was fine for 2 days. While sitting in idle I noticed the heat did not work. Now it's overheating again. Any advice? It has about 90,000 miles. The mechanic said that the water pump is fine.
Old Feb 27, 2011 | 09:17 AM
willrok13's Avatar
Have you been running DexCool? Could be your reservoir cap. If not the pump or thermo, it would be the next place I go (about $20 too, not bad if it's the problem). Stop driving it until you get it sorted. Good luck.
Old Feb 27, 2011 | 10:14 AM
Stop starting the engine before you toast your engine. Send me your number and I'll walk you thru what needs to be done.
Old Feb 27, 2011 | 10:21 AM
willrok13's Avatar
For future reference, what's the procedure?
Old Feb 27, 2011 | 10:50 AM
I suggested he send me his number, not to talk about how to bleed the system, he is past the spot already, but what to do before he drops a sleeve.
As for bleeding the system, do it only when stone cold, with the engine off, remove the bleeder screw and start poring fluid into the bottle, continue poring till you have a steady stream of coolant coming from the bleed hole, replace the screw and cap and go drive it for 5 or 10 minutes with the heaters both on hot and hi fan speed.
Let it sit till cold and refill the bottle up to the cap line and recheck it a few mornings later.
Only check the fluid level or bleed the system when stone cold.
Old Feb 27, 2011 | 12:28 PM
Snafu / Disco Fries's Avatar
Mike, where is the bleeder screw? On top by the hose connections? I might be thinking about something different.
Billabong
Jan 27, 2010 12:36 AM
StormTroopa
Aug 9, 2009 05:26 PM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
dpakman91
Freelander
Mar 14, 2006 04:29 PM
RovinLA
Sep 20, 2005 02:06 AM
