I removed the springs and Discovery is discharging the battery!
Easy
easy fix... make sure first your height sensors are disconnected or better take them out and tape the plug ends. go and pull the height relays and fuses in the fuse box in the engine compartment. they have pictures of which ones on the fuse cover. When you get a chance go buy dealer or better a indy shop and have them get rid of the height light on the dash. Your pump is probably constantly running your battery down....
Chris
Chris
And pull the fuse to the SLS compressor.
The compressor will try and raise the back of the truck, but because there are no longer air springs to raise the truck it will just run and run.
The main problem was the choice of our coach. He had never before worked as a technician. We should have hired Luiz Felipe Scolari, but "pressure" of the entity of the Brazilian soccer prevented.
[ ]'s
Caio
I've turned off the compressor: I removed the relay, disconnect all quechega the compressor. I removed the sensors on both sides. I removed the relay SLS (which is in the engine compartment). The alternator is charging fine. I do not know what to do I think a dealer and reprogram the computer. All that's missing it. But as I am at a distance of 300km, will go in my vacations. Until then I will testing and thinking what to do
Caio
Caio
Caio
Caio
I expect the compressor is still in it. There is a relay in the compressor, you may be able to hear it click once in a while.
Just pull the whole compressor out.
I went to two shops to get the thing fixed and one said the battery was bad, replaced it and it was dead when I went to pick it up. He didn't get paid.
Went to another one that said the alternator was bad (Land Rover Dealer)
I didn't give them a chance to mess things up.
When I got home, I heard the click and took it out. Haven't had a problem since.
You do NOT have to have it reprogrammed. One of the LR sites said it would continue to discharge the battery...that isn't true. Pull the compressor and all you have is the dash light.
intresting..thanks
Been there, done it and got the grey hair from it.
intresting...thanks..i think thats waht keeps draining my daughters truck...i am going to pull her unit tomorrrow...
Thanks Chris
