I think it's the fuel pump (Stranded Disco)
Old Dec 27, 2008 | 08:00 AM
2000 DII's Avatar
Default I think it's the fuel pump (Stranded Disco)
Hey all,
I tried to start it again yesterday and I didn't hear the ol' robotic noise coming from the fuel pump.
Is it a given now that it's the fuel pump?
Old Dec 27, 2008 | 08:21 AM
Default RE: I think it's the fuel pump (Stranded Disco)
The pump only runs in prime mode for 5 seconds then shuts off if the engine doesn't start. Have you taken a test probe to the power wire at the pump, if not don't start spending money on something you may not need.
Have you consodered that it could be the crank sensor that is not allowing the pump to fire up?
Old Dec 27, 2008 | 08:28 AM
2000 DII's Avatar
No, I haven't. 'm not sure how to go about that. Is there an access panel under my rear carpet that I can easily check that?
Old Dec 27, 2008 | 09:29 AM
YUP, just pull up the carpet, open the access plate and you will see the tank, wires and hoses.
All you need is a test probe and someone to cycle your key while you probe.
Old Dec 27, 2008 | 09:49 AM
2000 DII's Avatar
Sweet. Any special type of probe or am I just looking to see if powerlights upa test probe.
Also, is there anything special about getting the access panel open, type of bolts, etc.?
Man, that would be so sweet ifthis works out.
Where exactly is the crank sensor? I looked for it already, but didn't have adequate light to look around.
Old Dec 27, 2008 | 11:56 AM
jkid's Avatar
Any test light or a multi-meter set to 12v should do it to see what voltage it's getting.
I'm curious how easy it is to get to the pump myself, it doesn't look like the carpet is that easy to pull up, let us know how it goes.
You can see the crank sensor if you crawl underneath just behind the drivers side wheel and look up at the bell-housing just above the frame rail and exhaust. You should see a wire running into a plastic cover which is covering the sensor itself. It's pull it out andinspect it, shouldn't be too hard. If it's covered inmetal, rusty or bend it's probably bad.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
handsome rob
Nov 4, 2009 08:32 AM
lipadj46
Aug 19, 2009 06:11 PM
SH8KDWN
Jan 15, 2006 06:45 PM
