IACV running , humming, buzzing ?
03 D2
When you turn on your key to the last position before start and with your hood open does the idle air control valve make a humming or buzzing sound. I have never noticed this before it may just be running? Is it supposed to be running, buzzing, humming when the key is on?
trying to troubleshoot a problem and wondering if the noise is normal?
jfall, where can I buy a fuel pressure gauge with the right size adaptor for the schrader valve on 03D2.
Do you know what size that is. Most all of the fuel pressure test kits I see say not for bosch.
Only the high dollar ones say fits most cars and trucks world wide. I don't want to pay upwards of $100 for something I'll probably use only a few times.
I have a fuel pressure gauge now but it has the wrong size threads and I don't know where I can find the correct adapter or what size to look for. the adaptor cant just be a fitting from lowes it has to have a valve stem in it to depress the stem in the schrader valve on the fuel rail.
Thanks though. I'll eventually figure it out. I see adapters on amazon or ebay for a small type schrader but, they say for ford and not sure if it's the same. I doesn't necessarily have to fit my gauge I can cut the hose on the gauge and splice an adaptor in if I need to. I would buy any kind if it fit the truck. same size as a tire valve, i took off the cap and it would screw right onto my valve stem on the tire
I guess I should probably just spring for a good kit with the right adaptors if I am going to tinker with these trucks. It would be nice if I could find a gauge that just fit these trucks without all the other adaptors because I rarely work on anything else.
What is the name brand or model # of yours? If you don't mind me asking? Or if you see the right one anywhere on a website if you could send me a link.
thanks again for all of your help!
D2 2003
11-07-2017 07:41 AM
elboy0712
12-19-2010 02:48 PM
