Iat
Old Sep 24, 2017 | 11:11 PM
djfoxxy9's Avatar
Default Iat
IAT reading -40 on the scanner
03 discovery 4.6. Were would the short in the wiring be. MAF looks fine.
k
Old Sep 24, 2017 | 11:40 PM
number9's Avatar
MAF looks fine.
The IAT sensor has only electrical output. Output from the IAT sensor is measured at pin 34 of connector C0636 of
the ECM, this is a variable voltage/ resistance measured by the sensor to provide air temperature information to the
ECM.
The MAF/ IAT sensor share the same sensor earth. Sensor earth is via pin 9 of connector C0636 of the ECM.
Have you removed connectors from MAF/IAT and ECU to verified there is a short using a meter? Are you getting a IAT circuit low input failure code?
Old Sep 24, 2017 | 11:46 PM
djfoxxy9's Avatar
[QUOTE=number9;620628]Have you removed connectors from MAF/IAT and ECU to verified there is a short using a meter? Are you getting a IAT circuit low input failure code?
......[/QUO
Not now just P 0112 bad IAT MAF IS working
Speed racer
Oct 29, 2008 12:45 AM
tugumafu
Freelander
Sep 23, 2008 12:28 PM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
colby80210
Jan 19, 2007 03:52 PM
kng_kupa
Engine & Internal
Jan 4, 2007 06:13 PM
