Idaho wheel trade!
Well from what I have learnd Ther are two things to look for the bolt patern and I only know of two kind big and small! The other thing is Break calibers but the guy that looked at mine said I should be ok!
FYI the spacing from center to center of my lugs on the rim are 2" 3/4 apart I think the older rims are like 4" 1/2 ish from bolt to bolt! I think some Rang Rovers rims will fit too...
all d2s and 95.5-02 range wheels are compatible, past that the bolt pattern is the same as all newer models, inc new range, lr3 and sport, not lr2, however with the newer ones youll need a hub spacer due to different hub diamiters which doesnt work well with hub centric wheels
