Ideas on cleaning up the door panels? Where the elbow rests..
Old Oct 27, 2014 | 05:35 PM
cobbcj7's Avatar
Cool Ideas on cleaning up the door panels? Where the elbow rests..
I've been cleaning this truck up and I always frown at the door panel where it's not plastic, its just a stained fabric.
Can that part of the door panel be replaced or painted?? What can I do??
I would like to somehow paint if black to contrast the interior..
Ideas please..
Attached Thumbnails Ideas on cleaning up the door panels? Where the elbow rests..-683116__1.jpg
Old Oct 27, 2014 | 05:46 PM
cappedup's Avatar
I was thinking about covering mine in a black suede or felt or something. Thin leather sheet would be good, but I don't think it would be possible to mould it into folds of the door without looking gash.
I assumed the door card had to come off and it will be fixed from the back. That's a guess though.
Edit. Actually looking at your photo, try just taking the handle screws out. It might then slide up and off, if it slots behind where the window meets the door.
Old Oct 27, 2014 | 05:51 PM
Dave03S's Avatar
I used spray on upholstery/carpet cleaner and a stiff nylon brush.
It is not perfect yet but it actually did help quite a bit.
Old Oct 28, 2014 | 06:03 AM
zski128's Avatar
The material is Alcantara and its molded into the door card so it can not be replaced. Its easy to clean, some warm water with some Woolite diluted, dont soak it. If its all matted up you can use 1000 grit sand paper gently rubbing in a circular motion and a good stiff suede brush to make it look new again.
Old Oct 28, 2014 | 12:18 PM
acg's Avatar
acg
Use a steamer to clean it out. You can find some used and cheap portable ones on Craiglist. Steam will get the stubborn stuff loose. You can use a rag to wipe it off.
Old Oct 28, 2014 | 12:48 PM
CollieRover's Avatar
I am thinking about re-covering mine with perforated leather to match the seats.
rewi9d
Jan 16, 2011 03:23 PM
DiscoIIBrandon
Aug 19, 2010 02:23 PM
rduff
Jan 27, 2009 09:45 AM
SmyLeOrElse
Jan 22, 2007 01:26 PM
EASTLAND
Mar 30, 2006 01:40 PM
