Identify Source of Coolant leak
Old Oct 26, 2022 | 08:13 PM
GoldyGoldy's Avatar
Default Identify Source of Coolant leak
Hello all,
I have been trying to track down significant loss of coolant. I replaced throttle body heater, and took care of one of the leaks, but still losing a lot of coolant. I put some tracer in and the leak is dripping down from the fron of the engine. I don't see anything from the hoses or radiator and nothing lights up from the top of the engine. I was hoping someone could help me identify the source. With the engine running I could see a steady drip of coolant come down from where this yellow arrow is. Any thoughts? This is looking up, slightly to the drivers side of truck, just at the end of my arm's reach above the axle.
Thank you!
Old Oct 26, 2022 | 09:12 PM
Best4x4's Avatar
Front Cover Gasket, Water Pump Gasket, Lower Intake Gasket, Coolant Pipe Gasket, or HG are all possible from that spot.
Old Oct 26, 2022 | 09:25 PM
GoldyGoldy's Avatar
Thank you for taking the time to reply. Is there a connection in the cooling system right where the point of the arrow is? I could wipe it away and watch it start as a pinpoint and then a drip right at that spot.
Old Mar 7, 2025 | 06:58 PM
TheFrontRanger's Avatar
Found an independent shop that could do the work for a little less, but their google reviews are all over the place.
Vincent Goldini
Jul 6, 2023 11:19 AM
nashvegas
Oct 12, 2022 11:38 PM
LR2driver
LR2
Aug 9, 2019 10:08 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
kfox77
Feb 11, 2009 07:28 AM
